If you have an image but no backlight, the issue may be caused by the following:
- The LCD backlight circuit may be damaged and require replacement. This is a difficult repair, so replacing the entire display is recommended.
- The LCD flex cable may be faulty.
- Check the condition of the LVDS connector.
- Less likely: the motherboard section responsible for supplying backlight voltage to the LCD may be faulty.
