Hello, I need the BIOS for a Yoga 11e 5th generation (Type 20LM) (ThinkPad) laptop, BIOS 17833-1M.
I can't copy the original bin file
Please, while awaiting further developments, thank you in advance.
my friend , the 128KB is for EC icHERE IS MY BIOS NUMBER, AND IT IS 128KB, WHICH IS 16KB, BUT WHAT YOU PROVIDED IS AN 8KB BIN FOR A 64KB BIOS.
my friend
ouiii effectivement mais le bin que vous avez envoyer la taille est 8Komy friend , the 128KB is for EC ic
you should locate bios ic and program it
et quand j allume avec l ancien bios le pc émettre un son et rien de n affiche sur l ecranmy friend , the 128KB is for EC ic
its 8MBYes, indeed, but the BIN file you sent is 8KB in size.
its 8MB
that KB is just the suffix
you can go to file properties and check the size which is 8MB
da accord je vous ferai un retour
une question je n arrive pas a lire le bios d origine et il ne marche plus sur le pc donc dans ce cas je dois programmé le bios et le bios de l IOS aussigood luck
ouii cest ce que je me suis dis donc je prend autre bios de 8 kb pour le programme a nouveauif you cant read original bios then maybe the issue is related to chip faulty
i dont know about thisYes, that's what I thought, so I'm using another 8kb BIOS for the program again.
But what I can't understand is that my chip is 128 KB in size.
JE COMPREND LE MIEUX ET MERIC POUR VOTRE DISPONIBILITEmy friend , the 128KB is for EC ic
user51023 , Vahab Hemmati , RAYDTECH , Mbuch
