File Request Need Bios for Asus S533FL (X521FL)
stanislasandre
X421FL REV2.0
Laptop Model
ASUS VIVOBOOK S15 S533FL INTEL I7 10TH 16GB RAM
Hi!
I'm searching for a X521FL bios dump.
Thank you!
  • X421FL REV 2.0 .zip
good luck
what was device problem at first ?
i need bios backup to make a good working file
If the TPM is a TPM 2.0 and is not detected by Windows, verify that your computer hardware contains a Unified Extensible Firmware Interface (UEFI) that is Trusted Computing Group-compliant. Also, ensure that in the UEFI settings, the TPM has not been disabled or hidden from the operating system.
stanislasandre
That laptop can be installed on Windows 11, all the drivers are available into the Asus support website. Secure boot is enabled. With the file you shared, I have BSOD and fan is spinning always quickly. Sometimes, the laptop doesn't start Windows 10 and go to Bios Setup.
unfortunately there is no other bios dump file for this device
OK
but i think there is a need of original bios backup to solve that problem
