File Request Lenovo Yoga C640-13IML
Leotech
DA0LF3MB8F0 REV:F
Hi, i need schematic, the notebook blinking 3 times white led and no power, but the battery charging
Hi
unfortunately unavailable
try the below mentioned steps and see if the problem resolves:
  • 1. Connect the AC adapter to a known good power outlet. Check Power LED indicator on AC Adapter with/without plugging into the Notebook.
  • 2. If LED on the AC Adapter goes off only after connecting to notebook, the issue is with the motherboard.
  • 3. If the AC Adapter LED is ON, then remove external peripherals, battery, AC Adapter and press and hold the power button for 10-15 seconds to drain Flea power.
  • 4. Plug in the AC Adapter and battery and check if the computer powers on.
