20W1please send device type model
for example : 20J1 - 20DA
The computer itself doesn't turn on; there's only a signal at the charger.did you follow the steps above ?
you mean even with old bios ?The computer itself doesn't turn on; there's only a signal at the charger.
NO THE OLD ONE ITS WORK BUT THE PASSWORD STIILyou mean even with old bios ?
Seulement cette lumière qui s'allumei just sent your patched file above and instructions of use it
i did it with software and it has certain way
please check the file and instructions carefully
THE SAME only a signal at the charger.im sending you the latest update bios file for this device :
The old file working but it have password the patched and update bios not oni sent the patched and the update bios file for this device
now i really don't know how can i help in this case
please reprogram old bios and check
and if you have display then follow the instructions and program the patch file
insert wrong password 3 times and check if its showing any code on screenThe old file working but it have password the patched and update bios not on
banofils , mohabouzid128 , Vahab Hemmati , Admin , qamarlko2009 , user50911 , Salimeh Bolboli , sortek
