File Request Hp probook 430 g7 bios unlock
user61644
NMC
Hi, i need to remove bios pass of a hp proobook 430 g7.
The laptop have two bios 1º i think is the Main MXIC-25L12872F and 2º i think is the EC GIGADEVICE - 25B127DSIG
Which one you need the file to unlock? or you need the 2 files?
Thanks.
Hi
send both files
i need to check
user61644
NMC
Hi,
The file don´t work. I think is because it recover from the ec-bios.
And still with pass.
user61644
NMC
Hi,
No luck, the file don´t work. When i turn on the laptop it recover from the ec-bios.
Go to Solution. Turn off the computer, and then connect the power cord. Press and hold the Windows key and the B key at the same time, and then press and hold the Power button for 2 to 3 seconds. Release the Power button but continue pressing the Windows and B keys.
user61644
NMC
When i try Windows+B. The laptop don´t do anything. Turns On no image and don´t recover the bios or give image logo screen.
i think overall the problem is not only related to bios
user61644
NMC
OK, it works. Programing with the 2 files work.
Hi have another hp proobook 430 g7 with bios pass.
Can i use this 2 files? or do you need the original bios files to unlock like the first one?
Thanks.
send original files
user61644
NMC
Hi,
send exact motherboard model
  • DA0X8LMB8D0 test ok.zip
