File Request Dell Latitude E5570 with AMD GPU
Albrie
ADM80 LA-C642P Rev.1.0 (A00)
Laptop Model
Dell Latitude E5570
Hi,
Looking for a bios file for ADM80 LA-C642P Rev.1.0 (A00) with AMD GPU
Albrie
Hi, thanks for file, but that bios only works on i5 laptop without GPU and does not work on i7 with GPU.
Do you have file that supports i7 with AMD GPU?
  • Latitude E5570 new.zip
Albrie
Hi, thanks for file - Unit has display and working, but no WiFi or Ethernet ?
  • LA-C642P Clear.zip
  • Dell-E5570-ADM80-LA-C642P.zip
Albrie
try install driver pack
Drivers is not problem.
I found file that has working WiFi, but laptop takes 25sec to display. Bios update did not fix bootup time. If I ClearME WiFi does not work anymore...
  • GD25Q128B@WSON8_20220126_123550_CIT-Working (WiFi working).BIN
for some devices it happens after Clear ME like WiFi not work or HDD not detect and etc ...
the only solution is using a not Clear ME file
Albrie
I got the WiFi to work on ClearMe file. So I opened both files with FlashImageTool and changed ClearMe file settings under networking to be same as WiFi working file, then I build it. Now unit boot OK and WiFi working.
Thanks for help =)
Thanks for help =)
really good job
can you explain what do you mean by changing ClearMe file settings under networking ?
Albrie
really good job
I used the bin file with a ClearME and changed the WiFi settings in Flash Image tool so the WiFi will work
thank you very much
