File Request ASUS ROG STRIX X370-F GAMING bios Version 6042 bin file
mane
please do you have a latest bios bin file for the Version 6042 on motherboard ASUS ROG STRIX X370-F GAMING
i have a mb that turned of during the update process and cant bring it back to life
just try the file
mane
this is backup file that was in after it crashed
  • backup_iscitan.bin
that file is zipped
unzip it and try
you said the file is 7.8 MB !
mane
sorry didnt look after unzip
but it didnt help me after i tried it
the pc was working when customer tried to update bios for newer CPU to install on the board ,,then it crashed to them in the middle of the update procedure , after that it wont turn on all the way to boot it stops on CPU or VGA check it depends which version i write in the IC
in this case you need to check other parts of the board first
the bios which sent to you is tested working
mane
i will do that ,,already tried another cpu,ram and vga ,,,, could it be that the IC is bad ? it writes the file in and does the verify without error
  • ROG-STRIX-X370-F-GAMING Ver 6042.zip
mane
i have tried everything ,,, even copy the S/N of board with the fd44 editor ,,,stil no good efect
is there anything else that needs to do ,,any idea or sugestion will be much appreciated
